Mango OAuth 2.0 / OpenID Connect setup
Mango 4.0 Allows company users to use SSO for the login. You can use Google OAuth, and Microsoft / Office 365 / Azure Active Directory.
February 8th, 2021
Google
  • Open the Google APIs console here.
  • Create an OAuth consent screen.
  • On the Scopes page add “openid”, “email”, and “profile”.
Scopes
  • Go to the credentials page and create an OAuth client ID.
OAuth client ID
  • Choose “Web Application”.
  • Enter your Mango URL in “Authorized JavaScript Origins” e.g. “https://demo.mangoautomation.net”.
  • In “Authorized redirect URIs” enter your Mango URL followed by “/oauth2/callback/{Your Organization}” e.g. “https://demo.mangoautomation.net/oauth2/callback/{Your Organization}”.
  • Copy your “Client ID” and “Client secret” into your env.properties file.
  • Minimum configuration is:
authentication.oauth2.enabled=true
oauth2.client.registrationIds={Your Organization}
oauth2.client.registration.{Your Organization}.clientId={client id}
oauth2.client.registration.{Your Organization}.clientSecret={client secret}
  • You may wish to add a custom authorization URI with additional parameters e.g.
oauth2.client.registration.google.authorizationUri=https://accounts.google.com/o/oauth2/v2/auth?hd={your gsuite domain}
Domain-wide Delegation
  • Open the Microsoft Azure portal.
  • Navigate to “Azure Active Directory” from the menu at the top left, or the icon on the home page.
  • Choose “App registrations” from the left menu.
App registration
  • Click “New registration”.
New registration
  • Enter a name e.g. “Mango” and select your supported account type (you probably want to restrict logins from your own directory only / single tenant).
  • Under “Redirect URI” select “Web” and enter your Mango URL followed by “/oauth2/callback/{Your Organization}” e.g. “https://demo.mangoautomation.net/oauth2/callback/{Your Organization}”
  • Click “Register”.
  • You will need some pieces of information from the application home screen, clicking endpoints will show you the URIs you need to enter in your env.properties file.
Endpoints
  • You will also need a client secret, click “Certificates & secrets” on the left menu and choose “New client secret”.
  • Give your secret a description e.g. “Mango instance xyz” and click “Add”.
  • Copy the client secret “Value” into your env.properties.
  • The minimum configuration for your env.properties file is:
oauth2.client.registration.{Your Organization}.authorizationUri=https://login.microsoftonline.com/{Tenant ID}/oauth2/v2.0/authorize
oauth2.client.registration.{Your Organization}.tokenUri=https://login.microsoftonline.com/{Tenant ID}/oauth2/v2.0/token
oauth2.client.registration.{Your Organization}.jwkSetUri=https://login.microsoftonline.com/{Tenant ID}/discovery/v2.0/keys
oauth2.client.registration.{Your Organization}.issuerUri=https://login.microsoftonline.com/{Tenant ID}/v2.0
oauth2.client.registration.{Your Organization}.clientId={Application ID}
oauth2.client.registration.{Your Organization}.clientSecret={Client secret value}
Pre-grant consent
You can give admin consent for privileges (sign in and read user profile) on the “API permissions” page.
Pre-grant consent
Assigning Mango roles to users
  • You may wish to map groups/users from your Microsoft account into Mango. Note that there are several approaches to this with Microsoft, this is only one way of assigning roles.
  • Another approach is to add a “groups” claim via “Token configuration” then map Mango roles to the groups claim via your env.properties.
  • Click “App roles” on the left menu and then “Create app role”.
  • To create an app role that corresponds to the mango superadmin role for example:
Create role
  • Once you have created the role, you can assign users from “Enterprise Applications” on the portal home page.
  • Find your application.
  • Assign users/groups to the role you created under “Users and groups” on the left menu. Note that you can only assign “Users & Security groups”, not “Microsoft 365” groups.
