Mango v4 Released
Get the most from this site
How to Contribute on Docs From Github
Upgrade to v4
Installation
Installation Overview
Installing Java
Install script for Linux and Mac
Windows Installation
Linux installation
Mac Installation
Installation Configuration
Basic concepts
What is a Data Source
What is a Data Point
What is the XID for
User basics
User Interface Overview
How to set Data Point Values
Using the Auto Login feature
Where To Find Help
Basics
Introduction to HTML5 Web Apps
Getting Started
Data Point Details
Custom Pages
Editing the Menu
Events
Date Bar
Rollup
Users and roles
Linking Between Pages
Useful Resources
Watch Lists
Watch List
Watch List Builder
Watch List Charts
Dashboard Designer
Dashboard Designer - Basic Usage
Dashboard Designer - Drag-n-Drop System Status
Dashboard Designer - Dynamic Dashboard Workflow
Styling With Data
Enabling Auto Scale
Acquiring Data
Configuring Data Sources & Data Points
Data Point & Logging Settings
Bulk Importing Data Points
Adding and Using Tags
Checking Data Source Performance
Communication Protocols
SNMP
Alarms & Events
Setting up Event Detectors & Event Handlers
Advanced Alarms with Meta Data Points
Custom Email Templates
Slack Message Event Handler
Publishing Data
Configuring Publishers
HTTP sender publisher
Logic and Control
Advanced Scheduler
Scripting Overview
Meta Data Source
Scripting Data Source
Global Scripts
About Mango JavaScript
Script Examples
General Knowledge
Users & Permissions
Enterprise NoSQL Database
How to Use the Overrides Folder
Mango Rollups and Statistics
Reports
Create Excel Reports
LDAP Configuration
Mango OAuth 2.0 / OpenID Connect setup
Mango Cloud Connect Module
General
How to upgrade Mango
How to backup your Mango system
Starting in SAFE mode
Using the SQL Console
Managing Disk Space
Diagnostics
Server Info
Logging Console
Turning on Debug Logging
Threads
Work Items
Audit Trail
Internal Metrics
Security
Generate a SSL keystore
Content Security Policy
Request Rate Limiting
Using Certbot to get single domain certificates
Mango behind an Apache reverse proxy
Linux Security
Databases
Database Conversions
Migrating Historical Data to the NoSQL Database
NoSQL Database Performance Tuning
About the H2 Database
How to Restore a H2 Database Backup
MangoGT
Mango GT Education
MangoGT FAQ
Accessing the MangoGT
Changing Network Configurations
Accessing the OS through Webmin
MangoGT Connections
Using OpenVPN
Setting up Remote Backups
SSH Access to the MangoGT
SFTP file manager access to the MangoGT
Mango IO and Tools
HTML Components
Interactive SVG Graphics
Setting Point Values from Custom Pages
Dynamic Buttons
Linking to Dynamic Pages
Dynamically Generating Button List
Auto Rotating Pages
Dynamic Link to Schedule
Creating a Dynamic Floor Plan
Buttons to Set the Date Bar
Basic Tutorials
Custom CSS Styles
Creating a Custom Theme
User Module Setup
Custom Menus
How to Debug in the Browser
How To Develop Custom Views With AngularJS Components In Mango Automation
View Development with SVG in Mango
How To Use Tags To Organize Data In Mango
AmCharts v3 as a tool for graphics design in Mango Automation
HVAC Dashboard Development Tutorial
Overview
Prepare Development Environment
Create overview component
Create map component
Create selected unit card component
Create units table component
Create KPI indicators component
Create energy chart component
Create alarm list component
Build Java modules for Mango
Setup development environment
Custom Module Configuration
Our First Endpoint
Testing the module’s endpoints
Querying devices with RQL
Adding an AngularJS frontend
UI/Angular Developer
UI Development Process
REST API
Mango REST API Authentication
Explore the API
Java Developers
Mango Java Developer IDE Setup and Usage
FAQ
Mango Licensing FAQ
Resources
Modbus Point List Requirements
Reporting Bugs
Troubleshooting
After upgrade startup is stuck at 40%
Data points disappear in Graphical Views when editing after upgrade
A Mango page fails to load and Mango may complain with 500 - Server Error
Page Drop Down is blank in the Dashboard Designer or Edit Pages
Linux Diagnostic Information
Welcome to Infinite Automation's Support and Education Page for MangoGT
Installing & configuring
Common questions about MangoGT
Learn about licensing
Learn about MangoGT connections
Check MangoGT specs
