Installing Java
A guide about how to install OpenJDK 11 HotSpot
May 20th, 2020
Recommended versions of Java
We recommend installing a full Java JDK, while Mango should work with just a JRE we sometimes depend on tools only available in the JDK for our scripts and for providing support.
  • For Mango versions 3.6.x and higher we recommend using the Adopt OpenJDK 11 HotSpot.
Installing OpenJDK
OpenJDK is a free and open source version of the Java JDK. AdoptOpenJDK provies pre-built OpenJDK binaries for a variety of operating systems and architectures.
  1. Visit Adopt Open JDK
  2. Choose the JDK version you wish to install
  3. Select HotSpot JVM
  4. Choose your operating system and architecture
  5. Download the archive or installer (for Windows or Mac). If you download the installer see the installation for further instructions
  6. Extract the archive to your chosen location on your filesystem (e.g. /opt/openjdk)
  7. Set the JAVA_HOME environment variable to point to your installation directory
  8. You may also want to add the bin directory to your path by appending $JAVA_HOME/bin to your PATH environment variable
Setting your JAVA_HOME environment variable
Linux
Edit your /etc/environment file and add a line like JAVA_HOME=/opt/openjdk (Press Ctrl-X to exit, it will prompt to save)
sudo nano /etc/environment
Or a simple one line command:
sudo sh -c 'echo JAVA_HOME=/opt/openjdk >> /etc/environment'
Windows
  • Open “System Properties”, on Windows 10 you can search for “Environment Variables”
  • Click “Environment Variables”
  • Under “System variables” click “New”
  • Enter JAVA_HOME as the variable name and your JDK installation path under variable value
  • Press “OK” twice
env vars Windows
