Create selected unit card component
Showing the unit information when select it from the map
July 9th, 2020
This is the 4th article of a Dashboard development series. You can check all the articles by clicking here
In this article we are going to build a card like the next one:
Selected unit card component
It will be showed below the map when we select a unit in it (click here to see how to build the map component).
Let's start by creating the selectedUnitCard.js and selectedUnitCard.html files in the components/selectedUnitCard directory.
selectedUnitCard.js
 * @copyright 2020 {@link http://infiniteautomation.com|Infinite Automation Systems, Inc.} All rights reserved.
 * @author Luis Güette
define(['angular', 'require'], (angular, require) => {
    class SelectedUnitCardController {
        static get $$ngIsClass() {
            return true;
        static get $inject() {
            return [];
        constructor() {
        $onInit() {
    return {
        bindings: {
            unit: '<?'
        controller: SelectedUnitCardController,
        templateUrl: require.toUrl('./selectedUnitCard.html')
<md-card>
    <md-card-content>
        <p>Selected Unit</p>
    </md-card-content>
</md-card>
Then, we need to import it in hvac.js module:
hvac.js
define([
    'angular',
    'require',
    './pages/overview/overview.js',
    './components/map/map.js',
    './components/selectedUnitCard/selectedUnitCard.js',
    './services/unit.js'
    angular,
    require,
    overview,
    map,
    selectedUnitCard,
    unitService
    const hvacModule = angular
        .module('hvacModule', ['maUiApp'])
        .component('hvacOverview', overview)
        .component('hvacMap', map)
        .component('hvacSelectedUnitCard', selectedUnitCard)
        .factory('hvacUnit', unitService);
    hvacModule.config([
        'maUiMenuProvider',
        (maUiMenuProvider) => {
            maUiMenuProvider.registerMenuItems([
                    url: '/overview',
                    menuIcon: 'map',
                    template: '<hvac-overview></hvac-overview>',
                    menuText: 'Overview',
                    weight: 100
    return hvacModule;
}); // define
And, let's call the hvac-selected-unit-card component in the overview.html file:
overview.html
<div layout="row" layout-wrap layout-align="space-between start">
    <div flex="100" flex-gt-sm="50" flex-gt-md="60">
        <md-card>
            <md-card-header>
                <p md-colors="::{color: 'accent'}">Active Alarms</p>
            </md-card-header>
            <md-card-content>
                <hvac-map units="$ctrl.units"></hvac-map>
            </md-card-content>
        </md-card>
        <hvac-selected-unit-card></hvac-selected-unit-card>
    </div>
    <div flex="100" flex-gt-sm="50" flex-gt-md="40">
        <p>Column 2</p>
    </div>
</div>
When you reload the page, you will see something like this:
Overview page
We need to share the selected unit in the map component with the selectedUnitCard component. First, we need to update code on our map component.
map.js
    const DEFAULT_CENTER = {
        lat: 35.618379,
        lon: -78.413052
    const DEFAULT_ZOOM = 7
    class MapController {
            return true;
            return [];
        constructor() {}
        $onInit() {
            if (!this.center) {
                this.center = DEFAULT_CENTER;
            if (!this.zoom) {
                this.zoom = DEFAULT_ZOOM;
        addEventListener(map) {
            map.on('popupclose', event => {
                this.selectUnit(null);
        selectUnit(unit) {
            this.onSelectUnit({unit: unit});
    return {
        bindings: {
            center: '<?',
            zoom: '<?',
            options: '<?',
            units: '<',
            onSelectUnit: '&'
        controller: MapController,
        templateUrl: require.toUrl('./map.html')
  • We added an addEventListener() method to set the selected unit to null when on popupclose event.
  • We added a new callback binding called onSelectUnit.
  • We added a selectUnit() method, which call this.onSelectUnit({unit: unit}) to share the selected unit with the parent component.
map.html
<ma-tile-map
        center="$ctrl.center"
        zoom="$ctrl.zoom"
        options="$ctrl.options"
        on-move="$ctrl.center = $center; $ctrl.zoom = $zoom"
    <div ng-init="$ctrl.onlineUnitIcon = $leaflet.icon({iconUrl: '/rest/v2/file-stores/public/hvacDashboards/img/online-unit.svg', iconSize: [32,32]})"></div>
    <div ng-init="$ctrl.offlineUnitIcon = $leaflet.icon({iconUrl: '/rest/v2/file-stores/public/hvacDashboards/img/offline-unit.svg', iconSize: [32,32]})"></div>
    <div ng-init="$ctrl.addEventListener($map)"></div>
    <div ng-repeat="unit in $ctrl.units track by unit.name">
        <ma-tile-map-marker
                coordinates="[unit.lat, unit.lon]"
                riseonhover="true"
                options="{riseOnHover: true}"
                icon="unit.points.status.value ? $ctrl.onlineUnitIcon : $ctrl.offlineUnitIcon"
                on-click="$ctrl.selectUnit(unit)"
            <p class="title" md-colors="{color: 'primary-700'}" ng-bind="unit.name"></p>
            <div class="data-container">
                <div>
                    <p md-colors="{color: 'accent'}">Occupancy</p>
                    <ma-point-value point="unit.points.occupancy"></ma-point-value>
                </div>
                <div>
                    <p md-colors="{color: 'accent'}">Status</p>
                    <ma-point-value point="unit.points.status"></ma-point-value>
                </div>
            </div>
        </ma-tile-map-marker>
    </div>
</ma-tile-map>
  • We call ng-init="$ctrl.addEventListener($map)" inside ma-tile-map to add the popupclose event listener to the map.
  • We added a on-click method to the ma-tile-map-marker, so when we click the marker it calls the selectUnit() method and pass the selected unit.
Then, we update the overview component to get the selected unit:
overview.js
onSelectUnit(unit) {
    this.selectedUnit = unit;
  • We add onSelectUnit() method to set the selectedUnit variable, which will be shared with the selectedUnitCard component.
overview.html
        <md-card>
            <md-card-header>
            </md-card-header>
            <md-card-content>
                <hvac-map units="$ctrl.units" on-select-unit="$ctrl.onSelectUnit(unit)"></hvac-map>
            </md-card-content>
        </md-card>
        <hvac-selected-unit-card ng-if="$ctrl.selectedUnit" unit="$ctrl.selectedUnit"></hvac-selected-unit-card>
    </div>
        <p>Column 2</p>
    </div>
</div>
  • We added on-select-unit="$ctrl.onSelectUnit(unit)" to set the selectedUnit.
  • We added unit="$ctrl.selectedUnit" to pass the selectedUnit to the selectedUnitCard component.
Now that we have the unit information in the selectedUnitCard component, let's add this information, and update the style. You can download the location icon from here.
<md-card md-colors="{border: 'primary-700'}">
    <md-card-content>
            <div flex="100" flex-gt-sm="50" flex-gt-md="70">
                <div flex="100" class="title-container">
                    <ma-point-value point="$ctrl.unit.points.status"></ma-point-value>
                    <p md-colors="{color: 'primary-700'}" ng-bind="$ctrl.unit.name"></p>
                </div>
                <div class="data-container" flex="100" layout="row" layout-wrap layout-align="start start">
                    <div>
                        <p md-colors="{color: 'accent'}">Power</p>
                        <ma-point-value md-colors="{color: 'primary-700'}" point="$ctrl.unit.points.power"></ma-point-value>
                    </div>
                    <div>
                        <p md-colors="{color: 'accent'}">kW/ton</p>
                        <ma-point-value md-colors="{color: 'primary-700'}" point="$ctrl.unit.points.kwTon"></ma-point-value>
                    </div>
                    <div>
                        <ma-point-value point="$ctrl.unit.points.occupancy"></ma-point-value>
                    </div>
                </div>
            </div>
            <div class="location-container" flex="100" flex-gt-sm="50" flex-gt-md="30" layout="row" layout-align="start start">
                <img src="/rest/v2/file-stores/public/hvacDashboards/img/location.svg" alt="Location icon">
                <div>
                    <p md-colors="{color: 'accent'}">Location</p>
                    <span md-colors="{color: 'primary-700'}">{{ $ctrl.unit.lat }}, {{ $ctrl.unit.lon }}</span>
                </div>
            </div>
        </div>
    </md-card-content>
</md-card>
Finally, let's add some styles for this component in the hvac.css file:
hvac-selected-unit-card {
    text-transform: uppercase;
hvac-selected-unit-card md-card {
    border-style: solid !important;
    border-width: 2px !important;
hvac-selected-unit-card p {
    margin: 0;
hvac-selected-unit-card md-card-content > div {
    margin: 0 -1rem;
hvac-selected-unit-card md-card-content > div > div {
    padding: 0 1rem;
hvac-selected-unit-card .title-container ma-point-value {
    font-size: 1.375rem;
hvac-selected-unit-card .title-container p {
    font-size: 3rem;
    line-height: 1;
hvac-selected-unit-card .data-container {
    margin: 1rem -2rem 0 -2rem;
hvac-selected-unit-card .data-container div {
    padding: 2rem 2rem 0 2rem;
hvac-selected-unit-card .data-container p {
    font-size: 1.25rem;
    font-weight: 700;
hvac-selected-unit-card .location-container {
    padding: 1rem;
hvac-selected-unit-card .location-container div {
    margin-left: 1rem;
hvac-selected-unit-card .location-container p {
    font-size: 1.25rem;
    font-weight: 700;
hvac-selected-unit-card .location-container span {
When you reload the browser, you should see a page like this:
Overview page
Go to Create a units table component
