MangoGT Connections
  1. Gigabit Ethernet
  2. USB Port
  3. 5 VDC power plug not recommended for production systems
  4. 12-24 Volts DC Power Input
  5. RS-485 Connector
  6. HDMI Connector - for terminal access and optional HMI display
  7. AUX USB - Power to this port can be controlled through the system
  1. Status LEDs
  2. For models with expansion cards these terminals are used to connect to the internal IO card. Note. Standard MangoGT's will not have these screw terminals.
