Getting Started With SNMP
June 4th, 2020
SNMP Network Discovery
Under Administration > Admin home - Utilities click on the SNMP Import tool.
SNMP home
Click + NEW DATA SOURCE.
SNMP Point Import
Enter your Scan Settings and add a Data Source for the desired device.
Device scan
Now go back to the SNMP point import tool and select the device from the data source list. If you have a mid file you can upload it and then click START SNMP WALK.
SNMP walk
Select the data points you want to add and proceed to the PREVIEW AND CREATE POINTS tab. Click CREATE MANGO POINTS to add them.
SNMP preview
After the points are added you can use the Bulk Editor to modify the points further.
